Thread: Another gfci question.
    DIY Member hammerslammer's Avatar
    Dec 2005
    Colorado
    Default Another gfci question.
    I installed a Home Depot 3 pack of gfci's last June and they seemed to work great with the test button.
    This week I bought another 3 pack and a gfci tester. I installed one and it worked great. Then I put the tester on one I installed last June and it tripped and would not reset. Then tested another from last June and it would not reset. So I replaced the two that would not reset with two new ones and they worked fine. The wiring is exactly the same so I'm certain they were wired correctly.
    These were all the Leviton pro spec grade. Any advice??
    Thanks for all the past help on this wonderful forum. HS
    That's the price we pay for mass-production.
    Just my 2 worth.
    Dec 2005
    Colorado
    Is there a better quality/brand I should be buying??
    I use Pass & Seymour, but even they have had problems here & there. It's a crap-shoot. EVERY manufacturer will have problems now & then. Defective material is a function of mass-production.
    Just my 2 worth.
