Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
Thread: Hack Plumber? ... Oops -NO a licensed plumber!
  1. #46
    Dec 2006
    Yeah, they did an amazing job. Wish I had some pics of the final result.
    What you can't tell, is the floor all this is sitting on got completely reframed, as well. And one of the walls.
    Man, I felt bad for that crew.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
  2. #47
    DIY Senior Member construct30's Avatar
    Jun 2007
    NorthWest PA
    I take it you live in an area where it is hard and expensive to get permits for new construction. They put a lot of time and money into that. The end result looks great. It had to cost a lot.
  3. #48
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    You know what I would like see now? Is the plumbing&electric&HVAC part of the
    project.
  4. #49
    Dec 2006
    Quote Originally Posted by construct30 View Post
    It's impossible to get a permit for new construction there. National Park. The houses are grandfathered in. You can fix them, but you can't replace them.
    Depends on how you measure these things - it only added about 10% to the job, which was a complete gut to begin with, involving some very high-end finishes & etc. 700$ kitchen faucet? ...like that.
    Quote Originally Posted by cwhyu2 View Post
    project.
    Yup. New everything. Sorry, no pics; but they did a nice job.
    __________________
  5. #50
    DIY Senior Member Phil H2's Avatar
    Sep 2006
    Tujunga, CA
    Terry in Pa, we use the 2006 International Plumbing Code, if you have one read 305.8 protection against physical damage section.
    Construct30
    The codes (both UPC & IPC) are concerned with pipe passing through framing members. Subflooring is not a framing memeber. The orignial picture doesn't show the pipe passing through the joists. What do you do with drains and vents inside walls? Run a steel plate from floor to ceiling? I don't think attaching the pipe to the subfloor is ideal, but I don't think it violates any codes.
    IPC 305.8 Protection against physical damage.
    In concealed locations where piping, other than cast-iron or galvanized steel, is installed through holes or notches in studs, joists, rafters or similar members less than 1.5 inches (38 mm) from the nearest edge of the member, the pipe shall be protected by shield plates. Protective shield plates shall be a minimum of 0.062-inch-thick (1.6 mm) steel, shall cover the area of the pipe where the member is notched or bored, and shall extend a minimum of 2 inches (51 mm) above sole plates and below top plates
  6. #51
    Apr 2005
    Quote Originally Posted by Phil H2 View Post
    Construct30
    And that's why the plumbing inspector passed all those installs in the same fashion on the 2nd roughs. Good find Phil.
    As far as the couplings in that copper pipe; when I did new construction the guy I worked for would force us to keep using up pieces of copper coming off the ends of the pipe. Don't dare cut new sections cut to size off 10 footers or he'd hit the roof. He felt with copper couplings being .11 cents at the time that it was cheaper than pulling off a section of new 1/2" copper, $3.41
    Those days are loooooooong gone and I believe for good.
  7. #52
    Jun 2007
    NorthWest PA
    Phil H2 I wondered how long it would take some one to read the codes and point that out. I deal with two inspectors and I asked them and both said they would fail that. If you want to do it then by all means do it. I can't believe the number of plumbers that are defending such practices. The intent of the code is to protect the pipes in a home whether they are under ground through joist or under the subfloor. I guess I will have to contact ICC and have them add that part, I guess using common sense is not enough.
  8. #53
    Aug 2007
    Cincinnati OH
    The Intent of the code is to protect the public.
  9. #54
    Jun 2007
    NorthWest PA
    Sorry, I will be more specific, this section of the code we have been talking about for the past three pages.
    I guess this comes down to personal preference. I asked my inspectors and we are on the same page, but maybe some inspectors as well as some plumbers don't see it that way.
    I grew up around electricians and reading electrical code books, maybe some of that is clouding my judgement on this. I think I will still refrain from doing it though.
  10. #55
    Sep 2006
    Tujunga, CA
    I never said that I liked the pipe attached to the subfloor. I would never do it because I have seen too many subfloors that have had another layer addded with long nails. I wished I was wearing a hardhat everytime I have climbed into an attic or crawl space that looked like a porcupine on a steel diet. Personally, I'd rather see pipes attached to the subfloor than see nails poking through everywhere threatening my scalp. I quoted the code because I don't think the DIYers should be mislead into thinking that pipes (or electrical cable) must be 1-1/2" clear of the face of the subfloor, drywall, or siding. They would think their house has a defect when it does not.
    The codes are only a minimum standard. But, it would be ridiculously difficult to wire or plumb a building and keep everything 1-1/2" inside the wall. A person would be hard pressed to keep NM cable within those bounds in a 2 x 4 wall and you could forget about 1/2" copper pipe. That is why they make nail plates for the penetrations through plates and studs( http://www.strongtie.com/products/co...NSP-PSPNZ.html ). The code is concerned about where the pipe or cable passes through a framing member. Look at all of the electrical boxes designed for cable; the cable entrance is at the back of the box which places it very close to the drywall or siding on the opposite side of the wall. It would be impossible to use those boxes in a 2x4 wall if the cables needed to be 1" away.
  11. #56
    Dec 2006
    There's code, but there's also: "Contractor warrants that all Work performed pursuant to the Contract shall be performed in a good and workmanlike manner".
    Basic common-sense rule of thumb: anytime a pipe (or wire) is secured so that it can't just shift out of the way of a fastener, and it's close to the finish surface, it needs protection.
    __________________
  12. #57
    Jun 2007
    NorthWest PA
    OK so you don't like section 305 Protection Of Pipes And Plumbing Systems What about IPC 102.9. The inspector becomes god, little g.
    The general idea is that pipes and wires are to be run in areas that protect them as much as possible. You can run one wire down a 3.5" stud and it has to be straight as possible and in the middle. Inspectors tend to realize what is and is not possible when building. They still expect any tradesman to do the best job they can, when in their judgment you don't they slap one of those big orange stickers on your permit that says try again. What ever color they use where you live. I guess in this instance that's what this is, a judgment call. Ask your inspector.
  13. #58
    Jun 2007
    Licensed Grump
    I'm pretty much with all the above, I don't care whether code OK's it or not, I won't be clipping any pipes to subfloors anytime soon.
    Murphy's law almost guarantee's the carpenter would hit my lines, been there, done that, all set for the future.
