OK, here we go.
I have taken out an interior wall from my original bathroom (NLS) that joins onto a bedroom and created a 140 SQ bathroom. My house is a bungalo and I have plenty of access in the basement under this room to access the essentials.
The vent stack and associated plumbing and drainage has been relocated to accomodate the new shower stall, new soaker tub loaction, new toilet location etc...
The original tub has been removed and the original tub drain has remained. I plan to install a brand new front load wash and dryer set where the tub originally was. The dryer is a bottom vent so that is fine. The washer will be a floor drain using a 2.0 inch pipe with a back flow flapper directly into the sewer line to the septic. This wash water line will be vented from the existing (original) tub vent line. I am leaving the old tub drain in the floor for nothing more than a sense of safety if.....
My ultimate question is for purely cosmetic reasons. I prefer not to build a small step or install a water pan if I don't have to.
Thanks in advance
