Results 1 to 8 of 8
Thread: Delay in Toilet Water Refill, After Flush
    Default Delay in Toilet Water Refill, After Flush
    A few months ago this started happening. I've done internet searches, can't find that this happens to anyone else.
    It's a 1-year-old Toto toilet in a house. I flush the toilet, it always flushes great, and then silence. As much as a full minute later the tank and bowl refill with water.
    What is the problem?
    Thanks.
    It may be the fill valve needs repair or cleaning.
    If it's the Korky style, these would be the instructions
    http://www.terrylove.com/korky/
    One of mine did that for awhile, then started to operate normally. If you clean the screen, it may go away, or replace the cap assembly for about $3.00.
    Default what if I don't fix it?
    well, it's not inconvenient.
    Will it hurt if I just leave it alone?
    You could leave it, as long as it continues to fill at some point.
    The repair is less than $3 though, takes no tools, and takes less than a minute.
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    It won't hurt anything, but if it continues, it may eventually fail to fill to the line, which will adversely affect the flush. The same thing happened to my Drake after about a year. It has the Korky fill valve. I called Korky customer service about where to get a replacement cap. They gave me complete troubleshooting instructions and sent out a free new fill cap. Nice folks. I replaced the fill cap in about 10 minutes; problem solved.
    Thumbs up A grateful fan
    What a great forum!
    Thanks for the quick replies!
    I will check out Toto's customer service options....
    DIY Junior Member boctok's Avatar
    Oct 2012
    virginia
    There is a small valve in the bottom of the cup where the float is. Debris can get caught in this valve and significantly slow the rate that the water drains from this cup, which keeps the float from dropping and opening the valve. You can check this by removing the top cap and the float. If you have just flushed the toilet and there is still water standing in this cup, the small valve is clogged. You can take a paper towel and soak up the water which usually will also take up the debris.
