loveoldtrux
- Messages
- 7
- Reaction score
- 0
- Points
- 0
Howdy everybody!
I really want (the wife insists..) to move my current water storage tank for my deep to back behind the garage into a special shed I'm building for it. The "new" location would be about 40 feet farther from the house. The current well casing has pvc pipe leading from the saddle valve to the house.... this occasionally breaks and has to be dug up. I would ~like~ to use the 1" coiled pipe as it "gives" more without breaking and use it to connect the saddle to the tank T, then run the same coiled poly-pipe to the house and do away with the white PVC pipe that was installed 20 years ago.
For any kind of future "service needs" at the tank I plan to connect the poly pipe to a 90 degree elbow coming out of the ground and running to a bushing to allow me to run 1" copper straight up from there to a union (to make it really easy to service / remove / whatever) and then to the T at the storage tank. I plan to have a special shelf for the tank to sit on about 4' from the ground so that when the tank needs servicing somebody (me?...) doesn't have to stand on their head to look at the thing....(current tank is about 8" above the ground...). Then, would like to continue the coiled poly-pipe BACK out of the storage tank through the same kind of setup to the house.
Some questions, if I may....
1) Why was this cheap whit PVC used in the first place - just to save money?
2) Is the coiled poly-pipe not used because it is more expensive?
3) Seems from what I've seen at some builder supply houses all the fittings / busings / adaptors are available to let me hook up the poly-pipe - is poly-pipe less reliable than pvc?...
4) Can I run the line from the well casing to the tank and the line from the tank to the house in the same ditch (for a distance of about 30 feet)?
I have installed a poly-pipe well (230') many years ago - I liked it and it was easy to use (despite ripping my arm open on a steel clamp while lowering the pump down...) and through the years I've used PVC for everything from A-Z (even for removing truck axle bearings!!) so I can "go" either way. The pump casing will soon be surrounded by a concrete drive, so I need something that will last.
Would the above coiled pipe / copper pipe and unions work nicely? The reason I want to use the 2 unions on either line is to ~easily~ remove the tank if I need to - simply undo the two unions and the fittings to the T and the tank can be slid out for servicing / replacement... Naturally I would probably order everything through Terry for the installation....
Sorry for the long post
-Mark~
I like old trucks
-Mark~
I like old trucks
