Thread: I need wide caulk!
    Default I need wide caulk!
    shelby9@ptd.net I use to have a wooden box that housed the plumbing for my tub, I didn't like it and I wanted to put a shower head in so I took the box out and built a wall now I have the plumbing supported in the wall and a shower. Now I have a space to caulk that is very wide and caulk keeps cracking. I need HELP!!!! I am ready to scream!!
    DIY Member jumpyg's Avatar
    Jan 2005
    Michigan
    Try putting a foam backer rod in the joint before caulking. You should be able to find it at the hardware store or the construction section of Home Depot. You might be able to find 1/4" diameter backer, or just cut some 3/4" backer in half or in quarters.
    Default gap
    Unfortuately, the wall must not have been built "properly" or there would not be a wide gap. If there is any movement you may never be able to seal it properly. A silicone caulk may be strong enough, with sufficient flexibility, to seal it.
