Okay, well I will give a quick rundown of my project and I need some advise on a pump. I wish I had found this forum two weeks ago when I started this project. I have a stream/pond on my land that I want to use for irrigation. So I rented a trench digger and dug a 18" deep trench for the pipe to run from the water source to my house. Down in South Carolina this is below what frost line we have. I already goofed and ran 3/4" pipe instead of something bigger like 1 1/4" pipe. So I may re-lay larger pipe down the road someday. The water source is about 15ft below my house, however, I had to lay 230 feet of pipe. I had an old good working shallow well pump and tank that I tried to use, however I couldn't get it to prime. I've concluded that this is because of the friction of the long run of pipe. I have a foot valve at the water source. I'm in need of a pump that will work for this application. I planned on using a 40 gallon tank with it. Will just a external deep well pump work for this application? I was thinking of something along the line of a Goulds JRD 10? Any thoughts on this endevour would be appreciated. Thanks
-RJ
-RJ
