Results 1 to 15 of 15
Thread: Moentrol 3330 - pulling cart prior to soldering?!
Hybrid View
    DIY Junior Member nivlek's Avatar
    Nov 2007
    Alberta
    Default Moentrol 3330 - pulling cart prior to soldering?!
    Hi - I have what appears to be a rather difficult time doing something apparently very simple. I am attempting to pull the two cartridges from a Moentrol valve in preparation of pipe soldering.
    The instruction pamphlet indicates that this is accomplished is two easy steps:
    1. remove the two retainer clips (check) and
    2. use a pair of pliers to remove the cartridge from the valve body.
    However, no amount of pulling seems to budge the cartridges. They turn just fine and the "pin" moves in and out, but neither cartridge will actually slide out. I referenced the Moen website and while no instructions for the Moentrol unit were available, a number of animated sequences showing similar removal were seen. The pliers that I am using are garden variety and are starting to leave small scrapes on the brass finish. Not wanting to continue damaging the surface, I elected to get smart and seek advice.
    Any help, especially pointing out any or all of my stupid over-sight(s), would be greatly appreciated!
    Kelvin
    Apr 2005
    Take the screw that's intended to hold the handle on and screw it into the end of the stem so you don't mess that up.
    First I've heard of someone having trouble initially with a moen from the go; it's usually years later when you absolutely cannot get them to budge.
    Go to your local plumbing supply and get a cartridge puller; they work quite well in this application and will remove that cartridge without further adieu.
    Nov 2007
    Alberta
    Thanks Rugged,
    Is this tool available at Home Depot or should I seek a specialty plumbing supplier?
    Also, if the cartridge is "stuck" does that also mean that it is broken or defective. I guess the question is, do I need to replace the cartridges prior to reinserting them into the valve assembly?
    Apr 2005
    Yes......it's a very common item needed for moen faucets.
    No....it's a trademark problem with moen that'll never go away. Thus the reason there's a market for making the tools to remove the cartridge.
    Default Moen
    You mention "2 clips", " 2 cartridges", etc., but the Moentrol only has one cartridge and a balancing spool. If you intend to overheat the valve then you should unscrew the balancing spool also.
    Poster probably has the Moentrol with the transfer valve attached.That has two cartridges.
  1. Well pump shuts off prior to pressure switch cutoff
    By ABrown in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-26-2012, 05:43 AM
  2. Wiring for a 100 Amp Mobile Cart
    By VP Coffee in forum Electrical Forum discussion & Blog
    Last Post: 04-22-2011, 05:36 AM
  3. Moen 3330 Install Help
    By jdanbury in forum Shower & bathtub Forum & Blog
    Last Post: 01-26-2009, 05:56 PM
  4. Moen 3330 Valve Help
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 02-11-2008, 04:00 AM
  5. Problem with Moen 3330 Valve
    By Guest in forum Shower & bathtub Forum & Blog
    Last Post: 06-20-2007, 03:49 AM
