Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Metal framing
    Dec 2006
    Default Metal framing
    I know a lot of the electricians don't look at the rest of the forums. But AZ contractor & I had a question for you... How come there's no grounding requirement for metal framing?
    http://www.terrylove.com/forums/showthread.php?t=16713
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Jun 2007
    North Carolina
    If you are using metal boxes and the boxes are mounted to the metal frame and the boxes are properly bonded the metal studs are bonded through the process.
    Why would metal framing need to be grounded? Look at all the other metal stuff in buildings that aren't: Steel doors, aluminum storm doors, aluminum window frames, gutters & downspouts, metal drywall corner beads, copper roofs, aluminum & steel siding, metal cabinets, iron railings, garage doors, cast iron plumbing ......
    Just my 2 worth.
    In the Trades AZ Contractor's Avatar
    Apr 2007
    Phoenix, AZ
    I have no idea why they should be grounded. Then again, I have no idea why they shouldn't be grounded.
    So why should they be or why shouldn't they be grounded?
    Quote Originally Posted by 480sparky View Post
    The difference is obvious: The metal frame is all linked together, unlike the other examples you cited. Thus, if any one part of it becomes energized, the entire frame of the house would become "hot."
    I recently ran into a situation where a metal staple had punctured the sheathing on some romex cable behind a wall. The wooden stud had burned slightly during the short, but the breaker never tripped!
    I don't know how the wiring is affixed to metal studs, but if something similar occurs, where the frame comes in contact with a hot wire, and if the breaker didn't trip, that would be bad.
    If you were using metal studs with NM and plastic boxes I can see where it might be an issue.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Damn. I guess my instincts were right. Too bad for that guy and his family.
    Aug 2007
    Litchfield, CT
    What was up with the hack install? And the comment about being a homerun? Where do they find these guys?
    Dec 2006
    What I said, sorta - in NYC all the wire's BX, so anywhere it goes through the framing... this afternnon on the train I was thinking "and duh, the boxes are all screwed to the studs!" Because it's all metal boxes here, too.
    But then there's jurisdictions where metal framing goes with NM, and bushings, and (I assume) plastic boxes (?).
    LOL. Neither of you followed my link, huh? I brought up all the hurricane strapping and filch plates and joist hangers and shear panels in a coastal house.
    But then I considered that none of that's all connected to each other, like framing...
    I'm hoping you will click on Chris' link, I'm curious to get your views. How about it? Should there be a provision for grounding metal framing?
    __________________
    DIY Senior Member BrianJohn's Avatar
    Jun 2007
    VA
    In commercial applications it is "almost" impossible for the metal studs not to be grounded, due to the use of metal boxes, anchoring the track to the concrete and other metal structures in the building coming in contact with the framing members. In residential applications the only reason I can see why they are not grounded, is there have been no incidences that have brought this issue to the attention of the Code making panels.
    Obviously.
    There MAY be something now , I don't know.
    Central Florida
    A real freak accident. It's not clear to me why "bundling" the cables would have prevented the accident, as implied in the video. I've always felt the opposite way -- that leaving cables loose allows them to move out of the way of wayward screws and nails. Something had to have held that wire in place while the screw advanced... I would like to know why that cable was being held in place less than 5/8" from the backside of the drywall with no protection? Isn't there a 1 1/4" minimum requirement somewhere in the Code?
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Mikey View Post
    When the used the word "bundling" I believe they meant strapping the wire... (it was just an example they were showing of other wires done correctly, the wire that got hit was just free flowing in the wall...)
    as far as the 1 1/4 rule, it would fall under 300.4 (D)
    Central Florida
    Quote Originally Posted by Chris75 View Post
    My point exactly. Couldn't have been "free flowing", or it would have moved when the screw hit it. Probably was hit close to a fastened point, so the cable wasn't truly free. I've experimented a little with screw guns and nail guns going through 1/2" sheetrock into a stud cavity where cables were run -- never been able to pierce "free flowing" 14-2 or 12-2 cables with a screw, but nails are a problem due to their high velocity. Some of the heavier cables (e.g., 8-3) have enough mass that a nail will almost always pierce them before they've had time to move out of the way.
    Thanks for the Code reference; that's what I was thinking of. Interesting that the requirement is for cables running parallel to the studs only. In the video, it looked like the cable was perpendicular to an adjacent stud, but I may have misinterpreted what I saw. It was a 1 1/4" screw, not 1 1/8" as they said, but that's a nit.
