It sounds like you might have a cracked pipe or the drain trap is not right. I would look to see if the floor is damp under the sink and check the pipes for holes. Sometimes when the drain has an odor problem it will stink more from hot water because of the steam. If you could post a pic of the drain under the sink that could help a little.
