KRC
I have a single handle shower valve that is leaking. I do not know the model, but the outer plate is stamped delta. My problem is that when I turn off the water and take of the handle, I am not sure how to proceed. I tried to turn the knurled ring, but it is real tight and I don't want to torque the valve off form the piping behind - there is a chrome space behind the knurled end that turns freely, so there is no way to generate opposite leverage to protect the piping. There was a horseshoe clip that I also removed, but could not pull off the heat control piece (the one with the set screw in the picture).
Can someone identify this setup and tell me the best way to fix. Thanks!
