Results 1 to 12 of 12
Thread: Rough Opening for Door
    DIY Senior Member nelsonba's Avatar
    Sep 2005
    Minnesota
    Default Rough Opening for Door
    I'm planning to use some doors for my remodel project that are not pre-hung. (They were in my storage space and match the rest of the doors in the house). What would be the proper size rough opening for the framing? I assume I need enough space for the door jambs and some room for shimming. What would be the standard door jamb thickness? How much room do I need for shimming?
    Typically you would add 2" in width and height, but you should have the actual frame on hand, or specs for it, to be sure.
    A typical 36 X 80 door would be roughed at 38 X 82
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by nelsonba View Post
    Usually 3/4", and with the inch Jimbo mentioned allowed for them.
    The 1" allowance all-around should be more than enough unless the "rough framing" is a bit too "rough" and way-out-of-square.
    Use tapered shims in pairs with one coming in from each side so the net result is flat unless the lumber around your opening is twisted. Also, be sure to shim directly behind the hinges, if necessary, and to screw at least the top hinge all the way into the framing to keep the door edges plumb/parallel with the jamb.
    In the Trades AZ Contractor's Avatar
    Apr 2007
    Phoenix, AZ
    Quote Originally Posted by leejosepho View Post
    Where do you get 1"?
    Nov 2006
    Quote Originally Posted by AZ Contractor View Post
    Typically you would add 2" in width and height ...
    What number or numbers do you use?
    Apr 2007
    Phoenix, AZ
    Jimbo is correct. 36 inch door gets a 38" RO.
    35 3/4" door
    + 3/4" jamb
    + 3/4" jamb
    +3/16" gap on strike and hinge side.
    =37 5/8"
    the 38" RO gives you 3/8" of play.
    where do you get 1"?
    Nov 2006
    38" - 36" = 2" (1" all-around)
    What part are you missing?
    DIY Senior Member Hube's Avatar
    Ontario
    answer; it could be part of his brain that is missing
    Nov 2006
    Oh, maybe it is something as simple as "all-around" being mistaken for "overall", eh?!
    Overall, we are talking about allowing an inch all-around ... yet I did recently frame a wall and install a 4'x6' window in my new workshop with only 1/4" clearance overall!
    Apr 2007
    Phoenix, AZ
    When you mentioned 1" all around and rough framing way out of square in the same breath it sounded like you were talking about shim space.
    Dec 2006
    As opposed to the 3/8ths AZContractor just explained...?
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Nov 2006
    Ah, okay. I did not speak clearly while meaning to say 1" all-around the actual size of the door should leave enough room for jamb, shims and squaring, overall.
    Quote Originally Posted by frenchie View Post
    No, openings for windows are figured differently, but yes, 3/8" could have been okay.
