Here is what I have so far.
Question 1) Are these the correct connections? Shower drain is 2" and picks up the sink drain which reduces down from 1 1/2". Shower vent and sink vent are both 1 1/2". Question 2) Does this need to go to 2" when they combine? Toilet drain and main stack are both 3". Main stack is new and will run all the way down to the basement and tie into the existing stack. Let me know if you need clarification on anything.
I'd also like feedback on the wall framing. I offset the wall the sink is on because otherwise I would have a joist in the way of the sink drain and shower vent. Is this necessary or is there a better solution?
Let me know if you need to see other views.
Shower and Sink Vent Horizontal Turn Connections Version 1.jpg35.8 KB · Views: 3,394
