RickyAirtime
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I have a point in the basement, it's an old house, and believe it's less than 25 feet deep, as a shallow well pump works. The water is excellent, but the pressure is low and I believe the point was plugged.
A plumber yesterday suggested 1 Gallon of Mauratic Acid, let it sit 3 hours, then pump it out. So I did.
Trying to prime, I found 3 holes in the main steel pipe going into the dirt floor.
Possibly from the acid.
I patched them with JB Weld, but still cannot get prime.
Could I have damaged the point?
Could I have damaged the pipe further down?
Will I need a new well? My neighbour replaced his well recently, and has had
non-drinkable water since, so I'd like to avoid that, plus the obvious cost.
The acid has been in there almost a day now, is it making it worse?
Thank You .... Rick
Thank You .... Rick
