PHIL M
I have a leak at a 3" PVC fitting in my hot tub. It's impossible to go any further back to cut out and replace the elbow which I enlarged too much when I took out the original flexible PVC pipe which had collapsed. The new flexible pipe which I glued in just won't hold water at this joint. Only possible solution I can think of is to wrap the joint with some sort of epoxy. Found two products online which claim to be able to do the fix: Repair Bond and Plast-Aid. Has anyone used these products or have a different solution for me?
