CAUTION. YOU MAY DIE
Could be a number of scenarios. You will need a voltage tester or work it hot and touch some stuff together.
Is there another switch that also contriols the lights?
If not, it is likely that one of the 3 wires will be hot and the other two will be switch legs going to the track and the added cans.
All a switch does is connect the hot wire to the switched wire. If you touch the hot to the switch leg, it will spark and the light will come on.
