The pressure switch may still be closed however is the pump still running? I suspect you are pumping the well dry, the pump, both old and new were going into thermal overload and shutting down, starting back up and the well had recovered some so they continued to pump. Listen at the well head, you can hear the pump suck air.
Rancher
