Results 1 to 2 of 2
Thread: Bathroom remodel
    Default Bathroom remodel
    Is it okay to install a prefabricated shower over ceramic tile. Also, how would you install a marble threshold to transition from ceramic tile to carpet. Should it be installed on cement board or the subfloor which is plywood. Which type of adhesive should I use?
    thanks for help,
    chapskip
    The pre-fab bases require a flat surface. If the existing tile was a floor, and not an old shower, then it should be flat. It also requires level, so check that. If it was an old shower you are hoping to reline, not a good choice.
    While you could probably put a marble base directly on plywood, it would probably be better if it was over cbu. Thinset or a medium bed mortar would be the best choice. You want all the minor imperfections filled in so it is 100% supported, and gluing it down isn't likely to do that. Mortar will.
