By federal regs, a showerhead can't use more than 2.5gpm, so with two heads max, it probably won't make much difference...I concur. It gets to be more of a factor if you've got more heads. The 1/2" valve is less expensive. Now, if you had 3/4" supply lines and were filling a big tub, that would be a different story.
