Results 1 to 13 of 13
Thread: TOTO Aquia, we have them in Seattle
    Default TOTO Aquia, we have them in Seattle
    We have plenty of TOTO Aquia toilets for the Seattle area now.
    We just picked up 40 of them.
    TOTO toilets in Seattle
    Default Aquia toilets
    Do you have performance / recommendation info on the Aquia EL (CST 414M)?
    Customer Service Manager Plumbing Wholesale Peanut9199's Avatar
    Apr 2007
    Ontario, Canada
    CST414M: CT414 bowl, ST413M tank 800 on the MaP test
    Meets Los Angeles specification (SPS) for water savings sustainability
    Qualified to meet U.S. EPA WaterSense Specification
    Default Eco toilets
    Thanks, I was hoping for some plumber / consumer recommendations.
    I want to replace 2 toilets (one white, one biscuit, both elongated). I can get a rebate for using the high efficiency toilets.
    Is the EcoUltramax good?
    The Aquia is good looking, but I heard it is harder to install.
    None of these toilets are hard to install, but some are different. Plumbers don't like different. You have to drill some additional holes to mount the adapter to the floor over a normal toilet. Also, the water supply might have to be moved over, since they have a skirt that is sometimes wider than standard. Since many installations are not standard in the first place, you may not have to move anything.
    Note, Toto makes many toilets that use standard installation that any generic toilet will fit, too.
    The Toto Aquia works very well, I had one installed in my home for two years. It does take a little more time to install.
    The Toto Eco Drake works well too. An easy installation.
    DIY Junior Member jcg1545's Avatar
    Nov 2007
    Canada
    something to be aware of though
    if you are install an aquia in a visible area such as I was (pedestal sink, doorway facing entrance) the rough-in sticks out the back and is very visible
    had to return and now thinking of a carlyle as a substitute (wife wants skirted toilet)
    Default Condensation on Aquia Tank
    Have you seen problems with condensation on the Aquia? If so, is there an insulation kit to reduce the problem?
    There is no problem with condensation.
    ANY toilet, even an insulated one, can have condensation on it if it is in a high use situation. The only way around that is live in a desert or put a mixer on it to warm the water up.
    Quote Originally Posted by jcg1545 View Post
    I was wondering about that as well, I can see the plastic PVC sleeve from the side. Is that normal? Did I install that part wrong?
    You can see the end of the adapter on the Aquia, if you are looking from the side.
    If you are looking from this angle, it's hidden on the back side.
    Thanks alot.
