Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: light in shower
    DIY Member gfe76's Avatar
    Dec 2004
    Florida
    Default light in shower
    Roughing in standing shower. thinking about putting a shower ceiling light in with switch right outside shower threshold. Anything special about putting a light in ceiling of shower? (I plan on having a 16" square access panel in shower ceiling to get accesss to shut off valves.)
    Nov 2005
    Central Florida
    2005 NEC 410.4(D) says your lighting fixture must be listed for the location. I would also put it on a GFCI-protected circuit, assuming the switch is close by.
    Dec 2004
    Florida
    thanks mikey...that's what I thought (although I didn't know the code section). Can these lights be purchased at big box store as long as it says suitable for showers (wet conditions)? thanks
    DIY Senior Member rdtompki's Avatar
    Dec 2005
    Iowa
    Whe you say "light" I assume you mean a recessed fixture. You just need to make sure that the fixture has a trim option that is approved for damp conditions. I believe most do. There is certainly a limitation as to how close you can place an outlet to a tub. I don't know that this applies to switches and showers, but I wouldn't necessarily put the switch within arms reach of the shower.
    Rick
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Jun 2007
    NY State, USA
    Also, no GFI protection is required for recessed lights over a tub or shower.
    You can if you want, but it is NOT required.
    Quote Originally Posted by Speedy Petey View Post
    Some AHJs require GFI protection, so it's a good idea to ask.
    FWIW, here's the Code section:
    Just my 2 worth.
    Jun 2007
    NY State, USA
    Quote Originally Posted by 480sparky View Post
    Actually it is a good idea for them to provide a code reference if they "require" it.
    I had this happen with one guy who wanted GFI for switches within reach of a shower. He could not provide a written code reference so it was not done.
    It was a silly request any way.
    All they need to do is amend the NEC at a public meeting.
    Just my 2 worth.
    Jun 2007
    NY State, USA
    Exactly. They can't simply pull it out of their ass and say they want it.
    It MUST be in legal writing.
    I'm no pro, but I wouldn't put a switch near a shower if I didn't have to.
    (important note: I'm not a pro)
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by prashster View Post
    And I am a pro, and I wouldn't worry to much about it...
    Jun 2007
    NY State, USA
    OK. Why? Just because?
    He has probably been shocked from a switch cover plate screw before. I know I have.
    There is aways something creepy about touching a switch when you are wet and naked standing on a tile floor. impure water WILL conduct.
    Quote Originally Posted by Alectrician View Post
    Not to gross anyone out, but that is exactly what the human body is made of.
    Just my 2 worth.
