Results 1 to 10 of 10
Thread: Shower/Tub temperature
    Default Shower/Tub temperature
    The temperature setting on our gas water heater (brand new) is set to medium-high. The water temperature in all the sinks is very hot, as we like it. However, the temp in the shower in the master bath and in the tub in the guest bath is just warm. I see no obvious adjustment on the tub or shower handles to change the temperature. There is no logo on the handles. They are single handles that turn thru 270 degrees to adjust flow and temp. Any help would be appreciated.
    Plumber Plumber2000's Avatar
    Jan 2005
    Eugene, Oregon
    Have you removed the handle and looked to see if there was any adjustments under it?
    Plumber for 20+years
    Some of the single handle rotating valves have a limit adjustment to prevent people from accidentially setting it too high. As noted, check to see if yours does.
    There's a set screw holding the handle in place and a single screw at about the 1 o'clock position that looks like it holds on the face plate. Should I remove both of those?
    Jan 2005
    Eugene, Oregon
    Anyway to post a picture of this valve? Would like to see what your working with.
    My wife looked at it and found the Moen logo. (I missed it. Typical male) I will take a picture of it and post it tonight.
    Here's a picture of the fixture.
    http://www.moen.com/Consumer/product...kurefno=177884
    I don't think my picture made it, but the above link seems to be the right fixture.
    I guess I should try to read the user's manual downloaded from the above page. It appears that the temp change is seasonal and that I can adjust it. Right?
    Plumber jimbo's Avatar
    The picture you posted is of a Moentrol type. However they also make a Positemp pressure balanced type that looks the same from outside.
    http://www.moen.com/hidden/pdf/instr...&id=41f690809e
    This is a link to installation and adjustment instructions on one of the Moentrols. You can also find the Positemps on moen.com
    Thanks for the help. I'll give the adjustment a try if I can decipher all the plumberese.
