I don't understand the 'solid neutral.' It is a code violation to switch neutrals (unless you are wiring a gas station).
What you need is a 2-pole 30a switch. Another term for it is a Double-pole single-throw.
Can you provide a link to this website your found?
I thought I knew what I needed, a 30 amp switch. Sounds simple enough. The problem is this, I found a website that has 2 different 30A indoor switches. One is a 2 pole 3 wire and the other is single pole, 2 wire. Both with solid neutrals. The single pole, 2 wire is only 19.99 and the other is 31.99. They both say they are for water heaters. So which do I need???
