Try digging down in the center spot of grass.
It may have been the base for a flagpole, or an artillary emplacement, or one corner of a pole barn with no more pole.
Rancher
I need help figuring out if this is an old well, and if it is, what to do about it. How do I tell how old it is, and if it has been properly sealed off? How do I tell if there is still an old pump in it? Was this the base of a windmill or the floor of a well house, or???
The property on the edge of a small town in South Texas, in an area where there were some old houses that have been since torn down. The houses would have been some distance from this well, however. The house I am in was moved to the area. This well (?) does not appear on the survey of the property. It was hidden in tall weeds when I discovered it.
Please follow this link to see a photo.
http://kennedy.cartama.net/well.htm
Rancher
Coulda been just about anything. Old outhouse maybe?![]()
What I can tell you is that the concrete is about 5 ft square and the hole in the middle is exactly 2 ft across. Although the grass makes it difficult to see in the photo, the hole is a perfect circle and I can tell that the hole extends down (like a cylinder with smooth concrete sides) for at least 3-4 inches (that is as far as I felt with my hand).
A friend wants to stick a metal rod into the hole to see if it hits anything.
If you have any further ideas, I'd be interested in hearing about them.
Have you had oil exploration in the area?
It's very rare for wells to be included in surveys. Especially wells that are buried.
bob...
