Would it be possible to add a 4500gal pressure tank to my system? I currently have 2 80 gal tanks which give me about 20 gal of water with the booster pump set at 40/55psi. The pump currently runs only about a minute per cycle. If I put the 4500 gal tank in-line it would give me about 700gal of water under pressure, and with a digital pressure switch, I could set the cut in at 50psi and cutout at 55. Also, this pump is supplied by a 2500 gal tank feed by its own well pump. Would this work?
