Results 1 to 5 of 5
Thread: Cycle Stop Valve
    Default Cycle Stop Valve
    I have a sub pump with a Square-D Switch and a Bladder Tank hooked up to a shallow well and I'm using for irrigation only. Everything is working just fine except the Sprinkler heads are having a hard time shutting down. I was assuming it was because of the difference in pressure. My switch is cut on at 40 and off at 60 with the bladder Tank set at 38. The pressure is fine and also the volume. I was wondering if a CSV would help my situation. and by the way I have a pumptec also connected.
    DIY Junior Member aceto's Avatar
    Mar 2005
    new york
    from another posting I was told that pumptecs will not work properly with csv's.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Lawn sprinklers that aren't shutting down would be most likely caused by the zone valve(s) - for a start, you want valves with flow controls, and to have those flow controls throttled down, as that greatly improves valve closing.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by aceto View Post
    A Pumptec works by sensing the lower current to the pump when the water drops in the well. When the current is too low, below the normal current, it shuts off the pump until some time has elapsed so the well can recover.
    A CSV reduces the flow from the pump to about 1 GPM. Reducing the flow also reduces the current to the pump.
    If the current at 1 GPM is less than the "low-current" setting on the Pumptec, then the Pumptec will shut down the pump.
    Tried wet_boots idea and that fixed the problem. Thanks Bob NH for the info on the pumptec. Everything is working fine.
