A GFCI compares the current on the hot lead to that on the return line, and if they differ by more than about 5ma or so (might vary a little), it trips. There's something in the motor that has worn, and it is leaking current to ground. Adding a separate ground won't do much about the tripping, as the GFCI is not looking at the ground lead at all. You may need to repair or replace the motor.
