Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: hanging a tv over a fireplace
    DIY Senior Member Jeff1's Avatar
    May 2006
    So Cal
    Question hanging a tv over a fireplace
    Hi all. I'm going to be installing a tv over a fireplace. I've ripped out the drywall and will be installing additional support lumber as well as electrical and other cabling. I'd like to know if there are any special considerations for the wiring near the metal flu.
    It turned out to be a good thing I ripped out the drywall. I found termites and will be having them treated to a special day at the spa - all the bug juice they can drink.
    Any information will be greatly appreciated.
    DIY Senior Member Livin4Real's Avatar
    Sep 2007
    Indianapolis, IN
    If the fireplace is used you realize where the heat is going to go right? You'll end up with warped non-functioning pcb's inside the tv.
    Helpful Guides
    Sep 2006
    Phoenix, AZ
    If flat panel, you will have a very expensive piece of plastic junk...
    If non-flat panel style, that will be one heck of a pop-out to hold it...LOL
    I think you see a lot of TVs over fireplaces because most folks don't use the fireplace. It's a decorative thing mostly. Though I had a chimeny sweep argue that one with me. I guess he was trying to talk himself into a good business model.
    I agree with the above about the heat.
    Tom
    Default tv
    I personally would not want a tv mounted that high. Unless you have lounge chairs it will be uncomfortable bending your neck to look upwards.
    DIY Senior Member chris fox's Avatar
    May 2007
    near phoenix AZ
    I agree with HJ. Proper viewing should be just below eye level. I know a couple who have this up high setup and they want to change it, its annoying to be looking up..not natural.
    my.02
    Chris
    My daughter has a tv over the fireplace,
    Very annoying.
    However, for those that want to mount flat panels over the fireplace, they have mounting kits for that purpose.
    Open up the wall, and put the proper amount of backing in.
    While the wall is open, you can add wiring, you will need your cable hook up.
    If you want to get fancy, you could use a motorized mount that would lower it to a pleasant height.
    Why not just put the TV INSIDE the fireplace. Then get a DVD of a fire...
    DIY Member Backglass's Avatar
    Jun 2007
    New York
    I did this above our rarely used fireplace in our old house. It was your basic, cheap contractor "sheet metal w/firebrick facing" fireplace. I just made sure to fasten all the wiring to the studs as far from the chimney pipe as possible. I ran all the wiring to a nearby closet where all the equipment was (Satellite receiver, VCR, etc) and used a remote IR bug to control it all.
    The view wasn't perfect and it did strain your neck a bit when watching TV, but we needed the space and the other wall would put the couch up against the fireplace. It sure did look good when you walked into the room though.
    Engineer chassis's Avatar
    Sep 2005
    SE Pennsylvania
    Another vote for "don't put it up there". IMHO it's not a comfortable place to view it (neck) and doesn't look that great from a decor point of view. But to each their own.
    Default Hanging T.V.
    Hey Jeff,
    Everyone's coments were very interesting, however, I have a couple of thoughts of my own. I have done this once in the past for a customer and am now in the process of doing it in my own home. If you're set in doing this and the other coments have you a little scared, I might sugest you consider a gas log insert. The way that I did the one in the past and the way I am doing mine is that I built an entertainment center about 12 ft. long with a 36 in. book case on each end. That left 6 ft. in the center for my 48 in. gas insert and 12 in. ceramic tile on both sides and above. Then I built in my 52 in. flatscreen directly above the mantel. It looks very nice and seems to be no problem. By using the insert there is no more mess and everything that goes with burning wood. I don't know what your age is, but I'm sure the time will come when you think GAS. Good luck, Jeff.
    Sep 2007
    Indianapolis, IN
    Your still putting heat to a $3000 piece of plastic and also not doing your neck any favors by having it that high. Check with the pros over at www.avsforum.com they'll be happy to help.
    Helpful Guides
    My sister has hers above the fireplace...it is a major pain to watch unless you are laying down on the couch. Why pay that much for a nice display, then make it hard to watch?
    We installed ours about 42 inches off the floor above a credenza. Would not want it any higher. Our viewing distance is from 10 to 30 feet.
    I have been in room where it was above the fireplace, and viewed from about 12 feet or less. Major pain in the neck.
