Results 1 to 5 of 5
Thread: Running wire through header
    Default Running wire through header
    Wife wants a light installed above the pass-through/breakfast bar. This pass-through (PT) is a 4x6 rectangular hole cut through the wall separating the kitchen and our living room. It's a load-bearing wall, so a header was installed (2 2x10s sandwiching 1/2 plywood). Header sits on a jack stud at each end which is adjacent to a sole to top plate stud ("king stud"?).
    Anyway, the plan is for 3-way wiring to be run to this light. The supply line will have to come UP in a narrow chase created by the king/jack studs holding up this header and king/jack studs 5 inches away holding up a doorway header. All of this is interior framing. I was planning on drilling a 3/4' hole through the very top of the jack stud so that the wiring would come out at the bottom of and would be stapled to the header. A jamb will provide a chase for this wiring, and all will be encased in trim. At least, that's the plan.
    Is there code that says I can't drill a hole through the king and jack studs for wiring? Or can you come down from the top of and go through a header (i.e. drill 3/4" through center of header)? Inspectors are due out tomorrow.
    Thanks.
    Jun 2007
    North Carolina
    This is a building code question not an electrical code question.
    personally I would say no
    Default Inspection done?
    I am curious. Did you drill the 3/4 hole? I suspect it was okay but would like to know for my own future reference.
    DIY Member arfeller's Avatar
    Aug 2007
    Port Angeles, WA
    Would she be satisfied with one of those stick up battery powered LCD closet lights?
    DIY Senior Member construct30's Avatar
    Jun 2007
    NorthWest PA
    Maybe a little late, but code requires that any wire that is not 1 3/8" from the edge of a framing member has to be protected by metal, ie a plate or metal conduit. No, you cannot run a wire in the "chase" made by the trim.
