Thread: Plumbing,what kind of pipe to use
    Default Plumbing,what kind of pipe to use
    I live in an 1982 mobile home that has the old grey qest piping, which does burst once in a while. I'm getting ready to replace all of it. I would like to know which pipe is better, the knew pex pipe or copper tubing. I plan on useing a brand name in the pex called Zurn is that a good brand? And if I use copper I plan on useing the L type. Also can you glue pex? Thanks
    Plumber Plumber2000's Avatar
    Jan 2005
    Eugene, Oregon
    Pex can not be glued, go with pex all the way, if you must use copper then do use type l.
    Plumber for 20+years
    Plumber RioHyde's Avatar
    Cincinnati, Ohio
    I'm not "PEX proficient" as we are just now beginning to use it. I've repiped waterlines in and under a mobile home using type L copper before though. I can tell you that soldering while laying on your back is a pain in the dexterior. If given the option, I'd go with PEX in this application.
