Thread: heat pump buzzing
    DIY Member gfe76's Avatar
    Dec 2004
    Florida
    Default heat pump buzzing
    Tried to search this, but no luck. Atlanta area, central Hvac, heat pumps oustide, air handlers in basement and attic. Yesterday temps around 75 and heat pump condenser "buzzing" but fan not moving. thoughts? thanks
    Main contactor? If the compressor was trying to run and was stalled, it would likely either overheat or overload and pop the breaker. If the fan is shot, it, too would likely overheat. It might not draw enough to pop the breaker, but it would sure start to smell nasty. Once you smell burned electrical wiring, you don't forget the smell.
    Dec 2004
    Florida
    no breaker tripped. It seems to be running fine...it just "buzzes" every so often...do you think it is about to fail? thanks
    It could be as simple as something loose and is a sympathetic vibration, or something more serious. Hard to say without being there.
