Results 1 to 15 of 19
Thread: Wood Stove Hot Water Danger..
Threaded View
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Wood Stove Hot Water Danger..
    A Quote I Found: I DO NOT KNOW THIS PERSON!
    "A co-worker of mine put a heat exchanger in his furnace firebox. Without proper controls he quickly made high pressure steam and soon solder joints were failing and the system came apart in what sounded like several small explosions. His solution? Weld the damn thing together the next time. It held together, but it back-fed steam all the way to his artesian well and he had a nice geyser out back. True story."
    Scott
    In this case the pressure had somewhere to go. Without a place to expand the resulting explosion could cause injury or death.
    I am very interested in heating hot water using wood as a fuel source. I want to do this safely and efficiently. What are some general considerations before I even begin to discuss specific ones? I have 2 good engineering schools neary to me, and both do work on alternative energy. I may be contacting them, but I wanted the opinion of you pros first.
    The biggest obstacle to adding DHW systems to wood stoves is that EPA emissions certification virtually eliminates the possibility of taking heat directly from the stove. Any DHW collector that robs heat from the combustion process would almost certainly create a dirty burn that would fail the stove. That is why manufacturers of EPA certified wood stoves don't offer DHW collectors as optional accessories. There may be one or two available, but we are aware of none at all.
    TIA,
    Molo
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
  1. winter vent for house with wood stove
    By diyfun in forum Remodel Forum & Blog
    Last Post: 12-25-2011, 06:40 AM
  2. pump to solar/wood stove drainback water heating system inconsistant
    By trillium50 in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-06-2011, 08:32 PM
  3. Hot water from wood stove coil
    By Commonground in forum Water Heater Forum, Tanks
    Last Post: 02-22-2011, 02:09 PM
  4. Installing a Wood Stove
    By paperbag3 in forum HVAC Heating & Cooling
    Last Post: 11-19-2009, 08:07 PM
  5. Hot water from wood stove
    By Karl White in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2008, 01:32 AM
