rontarbert
Based largely on comments posted on this forum, I installed two Cadet 3"s in April '07. I'm happy with the flush -- old AS toilets unreliable. After a few months I noticed that the toilet refills at night. I tested it for leakage by marking the water line and it was very slowly leaking. After examining the flapper I noticed that it had several little blisters on the rubber seat. I do not use cleaners and the tank is hooked to city potable water. I checked the other toilet and it has the same problem. Home Depot (where I purchased them) does not have replacement flappers for this model. I don't see any other such problem posted. Could I be under a black cloud ? Does anyone know if Korky makes a replacement?
I think that others are having the same problem but unless you suffer from insomnia (like me) or happen to be seated on the throne when it refills you may not realize that the toilet is refilling. The refill is quiet and short in duration. As a temporary fix, I removed the flappers and burst the blisters with a safety pin. AS is sending new flappers. I would not let this problem stop me from recommending the toilet. AS will stop buying the rubber from China and all will be well.
Update 11/9/07
I rec'd the two replacement flappers from AS today -- there is no indication of any change to the material. My comment about AS using rubber from China was an attempt at humor since there was no indication of origin on the flappers but the boxes that the replacements came in are clearly marked "Made in China". It will take some time to determine if the original flappers were from a bad batch or that I should avoid my potable water.
Update 11/9/07
