Results 1 to 9 of 9
Thread: Toto Soiree
Hybrid View
    Default Toto Soiree
    Hi,
    Because of the information and opinions on this site, we bought a Soiree and matching wall mount sink. Both are Sanigloss and in Colonial White. The color was special order but both items only took 3 weeks to get here.
    The toilet works extremely well. It bubbles up for a second before flushing away and the walls are rinsed with water to help keep them clean. This is my first low flow toilet and you'd never know that there's so little water in the tank.
    It's in, works well. We're glad we got it. Thank you to all who contributed to my research.
    TOTO Soiree pedestal lav, faucet and toilet suite
    Plumber jimbo's Avatar
    Thanks for the update.
    Yes, the Soiree is one of the models which because of the skirt design,, requires the supply valve to be at least 5" from C/L of flange,8" suggested, as opposed to the more common 5~6". Sounds like your plumber had to move your valve, necessitating some repair work in the wall and or floor, whichever place the valve was.
    Customer Service Manager Plumbing Wholesale Peanut9199's Avatar
    Apr 2007
    Ontario, Canada
    Thank you for the feedback, i wish more of my customers did that.
    If i were to replace the toilets in my house i would pick the Sioree as well, i believe it to be the best functioning and best design of the Toto line.
    Your plumber could have purchased a shutoff valve that would work with a skirted toilet, but most do not know they are available.
    http://www.dahlvalve.com/products/toto_toilet_kit.aspx
    The problem is the skirted toilets block the stop valve making it hard to get at to turn off but the new valves angle it to make it accessable.
    Terry's note: The Soiree needs the water shutoff valve at least 5" to the left of center.
    If it's less than that, the ones pictured can be used.
    The Carlyle skirted bowl needs 7"
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    The other problem with skirted toilets, at least in my case, was that the back part of the skirt comes close enough to the wall that the water supply not only has to be relocated a few inches to the left, but also really has to hug the wall - can't stick out too much...
    You are all very welcome.
    It's a silly name, though. It's French for "evening party".
    DIY Junior Member
    Mar 2010
    Pennsylvania
    Hello,
    I am new to this forum although I read a lot of it while researching a new toilet. I installed a Toto Soiree two weeks ago.
    I have a problem that I hope you have a solution for.
    My wife told me that 4 times, she had to use toilet paper to clean the bowl after using our new Toto Soiree toilet. This was not a problem on the replaced 3.75 GPF American Standard. The smearing happens during the flush cycle. She is upset because this is the first floor toilet that guests use. I have not had the problem. My wife is a vegetarian, I am not. Again, the bowl was clean before the flush cycle and the soil was above the water line in the front of the bowl. I did not actually see it as she is too lady like to show it to me and I could tell she was a little embarrassed even mentioning it to me.
    I thought that maybe there was some manufacturing residue in the Sanagloss bowl. Being brand new, it was never cleaned. I shut off the water and flushed the toilet so the water in the bowl was at its lowest level and more porcelain was exposed. I used Dawn dishwashing liquid and paper towels to really scrub the entire bowl, from the rim to as far as I could reach down the trap with my gloved hand. I then flushed it twice to get out all the suds and burnish dried it with clean paper towels. It sparkled!
    Last night we had company and my wife's worries were proven valid. She called me to show me a two inch smear (not hers) on the right side of the bowl, above the waterline. Three flushes did little to diminish it. I had to reach in and clean it with toilet paper. I was not happy.
    I need to get another toilet for this bathroom if you do not have a solution for this problem. Is there another toilet in the Toto lineup that will work better?
    Am I expecting too much from a 1.28 GPF toilet coming from an old 3.75 GPF model?
    Is the American Standard Traditional Champion 4 one piece toilet better than the ones that your members seem to dislike?
    Thank you,
    Jim
