Results 1 to 4 of 4
Thread: Silver solder 4%?
    Default Silver solder 4%?
    Silver solder 4%?
    What is the difference between Silvabrite 96/4 and Stay Brite 96/4 silver solder?
    Just curious why Silvabrite is listed as 6,000 psi tensil and Stay Brite as 14,000 tensil strength?
    http://www.silvaloy.com/silvabrite100.php
    http://www.harrisproductsgroup.com/p...ING_SOLDER.pdf
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    don't know the answer but I would compare a few more manufacturers. whoever's numbers are the farthest out of wack are either bad at math, Geniuses or liars.
    Brent
    One thing to note is the composition is different.
    96% tin, 4% silver.
    I've never had a "lead free" joint come apart.
    The copper will break and tear before the joint does.
