The bearings may be frozen...a little oil (assuming it has oil cups) once or twice a season may keep it from siezing next time. If you can get it free, it might work. Does the motor humm? If it was frozen and there is no thermal protection, it may be shot, too (overheated). The furnace is probably shutting down because of one of two things...with no fan, the high temp overload is tripping it, or convection is allowing enough heat to cause the thermostat to shut it off. Excessive heat on the heat exchanger can create other problems. Damp places will mess with metals and controls
