Results 1 to 13 of 13
Thread: pre-formed shower niches
    DIY Junior Member Richard S's Avatar
    Jan 2005
    Washington State
    Default pre-formed shower niches
    I'm in the process of rebuilding my tub surround & will be using tile. I've been trying to find the best alternative to custom building a wall niche. I had previously found out about Recess-It which I didn't want to use as others had noted that the flange protrudes a bit out from the cbu & I didn't want to mess with feathering out the thinset to get the tiles to look right. I've found 2 other products: Duk Liners & ProForm that seem to not have the same problem as the Recess-It (see attached links). I was wondering if anybody had experience with these products. All input is greatly appreciated.
    Thanks,
    Richard
    http://www.ctile.com/DukLiners.htm
    http://www.noblecompany.com/proform2.html
    Plumber jimbo's Avatar
    If you look at the installation insructions in your links, they show that you install the niche over the moisture barrier ( I would caulk this joint) then the backerboard overlays the niche flange. This will be imperceptible, and the tiles lay on a perfecly smooth plane.
    Jan 2005
    Washington State
    Jimbo,
    Thanks for the reply. Have you used any of these products? The reason I'm asking is that I'm wondering if it's as easy to tile on the products as the manufacturers claim & also, if you feel that the quality of the products is up to the task as I'm worried about water leakage. I should have been more specific in my original post - sorry about that.
    Thanks again,
    Richard
    FlooringSupply lajoe's Avatar
    Oct 2007
    Los Angeles CA
    Default preformed niches
    HI
    I used them all, and I would highly recommend the preformed niches
    Check this online store http://www.tiledepot.us/ the do carry them all, and you can read abut their product too
    Noble and others make some nice ones. Check out this site for some examples of things and some ideas and help on tiling things www.johnbridge.com.
    Jul 2009
    North Vancouver, BC
    Default How To Build A Shampoo Niche for your Shower
    post(s) deleted by John Whipple
    Jul 2009
    North Vancouver, BC
    Default Designing Shower and Tub Niches for your Kids. Play Time and Shower Niches
    Jul 2009
    North Vancouver, BC
    Default Shower Niches made from scratch
    Feb 2011
    NW Ontario, Canada
    Nice work, John. I had to do mine with KERDI origami and preformed corners because it was the size of one wall tile. The flash on the camera doesn't do justice to the grout on the glass tile bands. They don't look that bad.
    Jul 2009
    North Vancouver, BC
    Default Kerdi Niches
    Jul 2009
    North Vancouver, BC
    Default Oversized Tall Shower Niches
    DIY Junior Member jono604's Avatar
    Nov 2011
    vancouver, BC
    Has anyone had success with the pre-formed niches from TileRedi?
    http://www.tileredi.com/
    They look pretty handy but I've seen some chatter about their shower pans being hard to work with.
    Is it true that the tiles have to be set with epoxy thinset and if so is it considerably harder to work with.
    I'm doing a full bathroom renovation (down to the studs) so I'm open to options for creating a niche.
    Building from scratch with framing and backerboard is an option but I'm also intrigued by the ease of creating a two compartment niche using one of the pre-formed models.
    Can anyone recommend a good brand that is easy to work with and provides a great level of waterproofing.
    thanks
    Jonathan
    Jul 2009
    North Vancouver, BC
    Default Pre-Formed Shower Niches for shampoo and soap
  1. Bathroom accessories and ready to tile niches
    By Moses Cohen in forum Shower & bathtub Forum & Blog
    Last Post: 03-22-2011, 10:23 AM
  2. setting new pvc drain height for pre-formed shower pan
    By swill777 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-02-2009, 08:07 AM
  3. Installing pre-formed shower base
    By dprocket in forum Shower & bathtub Forum & Blog
    Last Post: 03-16-2009, 07:16 PM
