Originally Posted by
Drivesme
OK, thanks guys!
I did do the baid-aid route, used some stuff called 'propoxy' which is working pretty well......so far.
I have opened up my supply lines in the past and they are galv. but they are really good shape, must have been replaced at some point.
The drain that I replaced was bad, and I mean really bad, but it's 80 years old and god only knows where it drained to.
Hopefully the band aid will work because I really do not want to get into the lead and oakum Dept. at the hardware store.
Is there some kind of rubber doughnut that can fit inside of the cast to replace the lead/oakum, just in case this doesn't work??
Thanks again!
