Results 1 to 10 of 10
Thread: How weird is this? Pipe soldering clamps
    Dec 2006
    Default How weird is this? Pipe soldering clamps
    Just got my catalog from Garret Wade... weird new tool this month.
    Anybody ever seen this before?
    http://www.garrettwade.com/jump.jsp?...&itemID=112376
    I'm thinking of the many conversations we've had about sweating pipe in difficult-to-reach spots, worries about scorching or starting a fire...
    Then again, I've seen GW carry some pretty silly stuff.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Jun 2007
    Licensed Grump
    Excellent idea, but I'd bet money it takes too long to heat.
    Feb 2005
    Talking Thats For Sissies
    We had something like that laying around
    the office years ago, I remember fooling with
    one when I was a kid....
    like Grumpy stated it takes too long to evenley
    heat up the pipe....
    Jun 2007
    Licensed Grump
    I prefer Mapp, but most like Acetylene in the event there's wet pipe.
    No doubt that thing wouldn't handle it.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Yet to burn down a house using open flame.I would keep ext and spray
    bottle of water close at hand.Looks interesting though.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    Quote Originally Posted by cwhyu2
    I use Acetylene have used Mapp in the past. I take extreme precautions when it comes to fire in or around walls.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    Nothing new about that tool, they have been around for more than 50 years.
    I've never used one and I think that there are probably few places where I would use one but it might be useful in close-quarters for repair work.
    Default tool
    1. I have had one for years,The clamps are bulky so it is not really suitable for closely spaced pipes or tight spaces.
    2. The instructions say to clamp around the pipe and let the heat flow to the fitting. It should be, "clamp around the fitting and apply the solder when it is hot".
    3. Just another item to find space for in the truck and maybe really only needed a couple of time a year, if that. I guess not seen or used mine for decades. (I think my son borrowed it).
    4. It will heat the joint quickly, but if you have to replace the jaws for each size tubing, it eliminates any efficiencies.
    Dec 2006
    Seemed pretty silly to me, too - I was sharing more for laughs than anything else. A scrap of drywall protects framing just fine, IME, for the ~10 seconds it takes to heat a fitting.
    Although I was open to someone telling me "they're great"... you never know... it looked like overpriced gadgetry. GW does a lot of that.
    I've never worked with acetylene, what's that like? I did graduate from propane to MAPP a few years back, under my plumber's advice - soooo much faster!
    __________________
    Jun 2007
    Licensed Grump
    Mapp is a mixture of acetylene and propane.
    Propane just doesn't cut it on wet pipes.
    Personally I found that acetylene does, but often roasts the flux inside the hub in the process.
    You get a feel for that, learn to back the acetylene away before overheating it.
    I just like Mapp because the tanks as light as propane so I can lug it along with other tools and my bucket...less trips.
