If this 30 gallon tank is good and is not waterlogged, you should be getting around 3 - 4 gallons of drawdown. So it's taking ten minutes to use 3.5 gallons of water. That's a pretty good leak. If the well is 30 years plus old, I would think you have holes in the casing.
You can tell if this is the case by timing it like you are doing over a long period of time. Like maybe a month. If that time keeps getting smaller, you probably have bad casing and it's slowly rotting out further.
bob...
