Results 1 to 7 of 7
Thread: J-box location
    DIY Member Bassman's Avatar
    Aug 2006
    Ventura, CA
    Default J-box location
    I need to install a junction box and my ideal location is right under the beam in the photo. The cabinets come to the lower double plate (96") so the box would have to go in that gap. Question: is it okay to chisel out to install the box? It would only be about 3/4 " out of each 2x6.
    The other alternative would be to surface-mount a box which would be hidden above the cabinet. Frankly this sounds easier and more friendly for hooking up the transformer that is going to be fed by the box and be right next to it. Thanks for any tips.
    Jun 2007
    North Carolina
    The box will need to be accessible after installation.
    Aug 2006
    Ventura, CA
    Quote Originally Posted by jwelectric
    The box will about 3-4" above the cabinet, either in or on the wall.
    DIY Senior Member Phil H2's Avatar
    Sep 2006
    Tujunga, CA
    Most building codes require a steel strap over notches in top plates. So you could not install the box and still have it accessible with the strap. Here is a link to a strap that commonly covers these notches http://www.strongtie.com/products/connectors/RPS.html .
    Aug 2006
    Ventura, CA
    Quote Originally Posted by Phil H2
    I guess I won't be notching those plates then. I'll use a surface mounted box instead. Thanks for the link to those straps, I'll be using them to address some other issues caused by the original 1952 plumbers who basically carved away some important looking frame members. I have a place to the right in that photo where there is greater than 5.5" cut through the plates. Is there a strap rated for that? Thanks.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    It is common for there to be a cut in one of the two plates. They are rarely long enough to go the full length of the wall. However, it looks like the beam is supported on those plates, so I would be reluctant to cut the in exactly that area.
    You are going to need access to the transformer so you might as well plan for access to the junction box and the transformer.
    Aug 2006
    Ventura, CA
    Quote Originally Posted by Bob NH
    The box and transformer will both be above the cabinet on the wall. As for cuts in the plates, there is a soil stack a couple of feet to the right where the entire wall is cut out for it to pass through to the roof, about 7" wide. I have no idea what is holding my house together. Probably just that T&G roof deck.
