Results 1 to 11 of 11
Thread: Old style faucet replacement
    DIY Member hammerslammer's Avatar
    Dec 2005
    Colorado
    Default Old style faucet replacement
    Are there replacements for this type of faucet. The sink was original to the house and is set up as a second sink in the laundy room. My wife likes it but i can't keep it from leaking without messing with the washers every 2 weeks. A replacement would be nice. Thanks for all the help on this site. HS
    Sound and Light Suppervisor for a School District tjbaudio's Avatar
    Dec 2005
    Wisconsin
    Have you replaced the valve seats? If not are the washers getting chewed up?
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    yes it would be nice. Yes they do still sell them. You will need to find out what plumbing supply house close to you caries them.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Jun 2007
    Licensed Grump
    My preference on rear mount faucets:
    http://www.rohlhome.com/
    Default faucets
    There are faucets like that in all price ranges, from the $40.00 imports, to $300.00 Dishmaster, or the single handle Delta model 500.
    Feb 2005
    Talking get the Delta
    We have had very good luck with
    the single handle Delta....for about 135..
    dont fool with the cheap imports unless you
    buy two or three of them and plan on changing
    them out every two years
    Default Ask
    First thing you should do when you buy a faucet is to ask the retailer whether or not they stock replacement parts for what they sell and if they dont find out what the turn around time is for getting them. Sometimes buying products from overseas can be a nightmare of a wait time for any kind of replacement parts. Just because a faucet is new does not mean it always works! Example would be on the last Kohler faucet I purchased for $399.00 was defective and leaked at the stem. They wanted to send a replacement part for it which I refused and had them send me a complete faucet exchange which they gladly took care of.
    tonysprofessionalremodeling.
    Default faucet
    If you are responsible for the cost (labor) of repairing the defect, why would you want to spend time replacing the good parts when all you need is the replacement item
    Default Point
    Why would I want to spend any time replacing any parts on a new item? If one part is defective who knows what else will be wrong with it. Besides when the machining area that the O ring fits into is not machined properly its kind of hard to replace just the machined part
    Quote Originally Posted by hammerslammer
    Some old faucets need an extra thick washer. In that case, doubling up on the washers or using a beveled washer would help. Also, as someone suggested, try to replace the seats. Seats are either square or hex. Seat wrenches come tapered or "stepped".
    Dec 2005
    Colorado
    Thanks for all the help. I got a nice T&S installed today and it looks and works great...
    I'm embarrassed to say I did try a Home cheapo and had my first experience with bad thread. I wasted alot of time but they took it back all buggered up. They will probably repackage and put it back on the shelf. I did look at 3 others on the shelf that were repackaged and it looked like some other fellows had the same problems I did.
    Anyway my T&S looks great and Momma is happy...
