Results 1 to 15 of 15
Thread: Need Whirlpool Recommendation from the Pro's
    DIY Member
    Sep 2007
    South Jersey
    Default Need Whirlpool Recommendation from the Pro's
    OK here's what I got...
    Looking to install a 72X36 rectangle whirlpool in an alcove, willing to do the flange kit on a drop-in unless the pro's advise against it.
    I only have about $1000 in the budget for this piece.
    I want the Jacuzzi Espree, BUT they don't make the RH Drain I need. I'm not into tearing up the floor to accommodate a whirlpool that will have me looking at the terlett I'm kinda ticked with Jacuzzi for limiting my selection like this...can't seem to find any good reason why they'd do that when their other similarly priced models come with RH/LH drain configurations. The least expensive Jacuzzi I can get in this size with RH drain is $1800...budget buster
    Looked at the AM STD Lifetime at HD, not sure about the flush-mount jets, but there are 10 jets Flex tube plumbing.
    Also considering the AM STD Cadet at HD, but I haven't seen this unit in the store. 8 jets...seems good enough...PVC plumbing, mfr specifies SCH40 in their repair parts, but I'm not so sure they're constructed with SCH40...
    Priced a Watertech 7236BW for $1131 at Lowe's, but it's only got 7 jets (just ONE for the back). SCH40 plumbing all the way. If the pro's think it's THAT much better, I may stretch the $$ and see if I can get an extra jet installed where I want it for the extra $51...
    Which one do the pro's think is best???
    OR is there ANOTHER good brand/model out there in the same price range I just don't know about yet?
    H E L P !!!!
    Walt
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    I would not jump into getting something you might not like. If you end up getting something your not to sure about you will be kicking your self later.
    I do know most people that get a tub like you want tend to use them once, and only once.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    DIY Member
    Sep 2007
    South Jersey
    I don't necessarily 'dislike' any of these tubs. I just want to know I'm getting the best I can for my limited budget. I'm asking the pro's to weigh in...
    As far as usage, we'll be using it alot as Mrs. Waltman and I have cranky backs and look forward to hitting the tub oon those days when they act up. So, we truly want to use the tub for its intended purpose.
    Another thing:
    American Standard & Watertech BOTH have lifetime warranties on the motors. Jacuzzi doesn't.
    Walt
    Feb 2005
    Omaha, NE
    Do you have a big enough water heater? (Or two?)
    Whirlpools take a LOT of hot water...
    And take a lot of time to fill...
    DIY Member
    Sep 2007
    South Jersey
    [QUOTE=SteveW]Do you have a big enough water heater? (Or two?)
    Actually this tub will replace a same-sized soaking tub. We didn't have a hot water problem with that tub, so I should be clear.
    If need be, I would beef up the water heater though. Well within my skill set
    Thanks for pointing out something that's often overlooked when folks are considering one of these tubs. Hopefully an unsuspecting whirlpool customer will see this thread and realize they may need to add a bigger (or additional) water heater to their to-do list.
    Walt
    Feb 2005
    Default Always get more jets....
    Pearl makes great wp tubs....
    Jedda makes good WP tubs....
    Pay a little more and get all the jets you can.....
    Their is nothing more disappointing in a WP tub
    than not haveing enough jets blasting hot water
    and bubbles up in your buttox.....
    you will get the feeling like you are missing out on something...
    spend the money
    DIY Member
    Sep 2007
    South Jersey
    MASTER MARK: "Their is nothing more disappointing in a WP tub than not haveing enough jets blasting hot water and bubbles up in your buttox....."
    TMI Dude, T-M-I
    Thanks for the tub recs, I'll look into these mfrs...
    Walt
    Feb 2005
    Talking Jedda ....Aquaglass...are both in-expensive
    http://www.aquaglass.com/family.cfm?tubtype=Whirlpool
    http://www.jettaproducts.com/
    as far as the hot water and the bubbles......
    this is what I have been told by many customers
    who went for less jets
    they always say that they wish they had more jets
    hitting their "lumbar" or lower back area
    yea ---right.....sure ...ok...
    i was not born yesterday
    DIY Member
    Sep 2007
    South Jersey
    I cannot speak for your customers who want more 'lumbar' jets, but I would think that 2 should be sufficient.
    From your website it looks like you put a whirlpool in your own bathroom. How many jets, and who's the mfr? I also noticed the PVC plumbing. Is the extra insul for noise, temp control, or both?
    Walt
    Feb 2005
    Talking that is a clark
    That is a Clark WP tub....
    36 inch x 6 foot
    It has two back lumbar jets
    and three on both sides
    it makes my wife happy
    it was sitting in a ware house since about 96..
    and I was able to procure it in 2004 for $225
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    I have a Pearl Bath Metropolitan that I purchased back in 2002. The cost then was a little less than double what you have indicated as your budget but I wouldn't have been happy with anything less.
    The Metropolitan is now available with an air-jet back massage option.
    As for the necessity of a larger water heater...I have a 50 gallon gas water heater and my tub fills in about five to seven minutes (plumbed mostly with 1/2 inch copper) and I have NO problem with the hot water running out. I do have my heater set a bit on the high side, maybe 130 to 140 degrees but anything hotter than 110 in the tub is going to be way too hot to get into.
    My tub has only two jets (true whirlpool action) and I get a complete relaxation in twenty minutes. I strongly recommend a multi-speed pump (I usually use the slowest or next-to-slowest speed) and an in-line heater. Please understand that the in-line heater does not allow for heating a tub of cooler water but only slows the rate at which the water will cool.
    As for cleaning (another thread?) I have never used anything but dishwasher detergent to clean my tub although Pearl Bath does recommend using a 1/2 cup of bleach every other month.
    My biggest complaint with this bathtub was that it came with the pump control mounted at the "head" (drain) end of the tub and I found it hard to reach that far to operate. I recently moved the control to about one-third of the way from the "back" end of the tub and now it is is in the perfect position. All it took was a 1-1/2 inch hole saw as the wiring harness was more than long enough.
    DIY Member
    Sep 2007
    South Jersey
    Mark & Furd...
    Great info guys, thanks for the help!
    Mark, $225 is the deal of the century!!! Anymore of those laying around?? Even with freight to NJ it's a steal!!! That's what I call a two-fer...the wife's happy with the tub and you're happy with the price!! WIN-WIN
    Furd, you've pretty much summarized everything I've been reading and learning about these things. Those Pearl Tubs sure are nice! What did you end up doing with the original hole???
    I'm still confused though, which is better? More jets or less jets?
    Walt
    Jul 2007
    So far the hole is still there. I only moved the switch a week or two ago. I think I can get a cover plate for closing an unused hole in a kitchen sink but I haven't yet looked.
    If you order the tub you can probably specify where you want the switch. When I ordered my tub I didn't think about the switch mounting. I also had ordered the in-line heater but it didn't show with the tub. When I called customer service they apologized profusely stating that I was sent a "stock" tub. They made arrangements to send the heater to a local guy who came out and installed it. I could have done the heater install easily enough but this way the guarantee was in full force.
    The question of more or fewer jets is a personal one. Pearl Bath was originally started by a woman (her name is Pearl) that wanted to replicate the jetted tubs used in hydrotherapy clinics. They only use two jets (some of their huge tubs have three) to enforce this whirlpool action. Pearl sold her company to Maax about five or six years ago. Using multiple jets will disrupt a true whirlpool action and the jets will be blowing directly on to the person in the tub rather than around the person as is the case with the true whirlpool. I've never tried a multi-jet tub but I can see how blowing directly on your body could be irritating as the jets are blowing with quite a bit of force.
    Feb 2005
    Talking Pearl tubs vs others
    Pearl tubs are actually closer to a theraputic whirlpool
    unit......or so they claim......their are two jets that
    swirl the water around and its supposed to be more
    relaxing....
    I prefer the ones with all the extra jets because you can
    put you back, feet, elbows, bottox, or whatever directly
    against a jet and get that part hosed down real good...
    without having to move or contort yourself all over the
    place to reach a jet....like you have to on the Pearl
    I just called my supplier and they
    claim that they still have few of the Clarks collecting dust
    in the back warehouse right now...
    I think that the one I bought the box was badly water damaged,,,,
    and I dont know what they
    want for something sitting around for
    so long and I would guess that it
    is not worth the time or trouble....
    also I amsorry to say that the one I have
    only has 6 jets, I though we had 8
    Speaking of extra jets, how does an air bath compare to a whirlpool? Why would you prefer one over the other?
