I would not hook it directly to the device. I would use coper pigtails. It is still aluminum and the problems are generally at the device terminals.
Hi all, Quick question about copper clad wire. My house was built in 1974, the aluminum wire was pigtailed and my box is all copper now. However, I noticed that I do have copper clad wire, the outside looks just like copper but a cut end shows AL. I was changing a bathroom gfi and noticed the wire was this copper clad AL so I searched online for safety. I found this on inspectny.com "J. Safety of HOMES Wired WITH COPPER-CLAD ALUMINUM WIRE - Copper-clad aluminum wire has a thin copper outer skin and a core of aluminum. Therefore it looks like copper, except on close examination of a cut end. Markings on the cable jacket would include "Al" or "Aluminum". There is no known history of connection overheating problems associated with copper-clad aluminum wire. No corrective actions are required for copper-clad aluminum wire."
I've also read this in other areas. My question - Is this true? Any expert opinions? Thank you in advance, Ryan.
The device needs to say "CU/CU CLAD" if you want to use copper clad on it. I'd still pigtail tho...
Spaceman Spiff aka Mike
