Hi, We would like to replace our existing sump pump which is a vertical switch, we just feel it is time. Our sump pump runs most of the year (11 months usually) and when it is running pumps out at least every 30 seconds 24/7. We would like to fit a swing arm sump pump and are thinking of a 1/2 hp. Not sure of the make and power of the existing. We feel that a swing arm would allow the pit to fill more and therefore pump more each time,rather than have it come on and off every 30 seconds as it currently does, which is very power costly. The fact that our pit fills so fast and pumps so frequently means we have to choose the right pump that won't overheat and is very reliable. Could you recommend a make of pump please that will be reliable and can cope with the constant on/off demand. Even a swing arm will have a heavy frequency demand, as the water flows in like a river. Are you familiar with the Bur-cam brand of sump pump? we are looking at cast iron as it will likely stand up better as we have the water softener system flushing in to the pit too when it regenerates, which I understand can be corrosive. If a vertical switch is more reliable, then we are willing to replace with the same.
thank you
thank you
