Results 1 to 6 of 6
Thread: Plumbers Putty Function under Faucet
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Plumbers Putty Function under Faucet
    Is the only function of the putty to keep water from getting under the faucet from outside of it?
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Yes it is!
    Sep 2006
    cold new york
    Thought maybe
    Gore Vidal.
    Apr 2005
    Putty is oil based......so unless it's on porcelain I would use a bead of silicone on the outer edge of faucet where it terminates at the top of the sink.
    The directions often say to wrap plumber's putty around the underside of the faucet, and one plumber I worked with packs the entire area of the underside of the faucet with putty.
    Since faucets generally come with a plastic seal to block water from leaking below, I don't see the need to use putty. I use the clear silicone that Rugged mentioned, but only if the plastic seal isn't working.
    Plumber Cass's Avatar
    Putty is much easier to remove than silicone so I will only use putty unless is is a surface that putty can't be used on.
