Results 1 to 7 of 7
Thread: Gutter Slope
    Default Gutter Slope
    Anyone know the correct slope for gutters (inches per 50 ft)?
    Also, what's the recommended spacing for the hanger supports?
    DIY Senior Member Livin4Real's Avatar
    Sep 2007
    Indianapolis, IN
    taken from greenbuilder.com
    3.2 Conveyance Subsystem
    If a straight run of gutter exceeds 60 feet, use an expansion joint.
    Keep the front of the gutter one half inch lower than the back.
    Provide a gutter slope of 1/16 inch per foot minimum.
    Provide gutter hangars at 3 feet O.C.(on center).
    Gutter should be a minimum of 26 gauge galvanized steel or 0.025 inch aluminum.
    Downspouts should provide 1 square inch of downspout opening for every 100 square feet of roof area.
    The maximum run of gutter for one downspout is 50 feet.
    Helpful Guides
    That's more info than I had expected. Thanks.
    Are you saying that you can no longer use the the plastic gutter systems? Or are the codes you outlined for commercial buildings?
    Sep 2007
    Indianapolis, IN
    I'd assume it would all be the same whether plastic or aluminum. I think the majority use aluminum, that's what most info is based on. I'm not a gutter man, but just had seamless put on ours after we put on the new roof. Looks great and the hangers are hidden, ended up around $4.50 a linear ft. for labor and materials. Also something to think about if your in a cold climate is the plastic ones becoming brittle in the winter and cracking or breaking.
    Brian
    Helpful Guides
    I went with the very light aluminum system that use the couplings that are supposed to snap together easily.
    Well, they're a pain in the butt. Next time I'll just overlap the gutter sections, seal and rivet them.
    water needs a slope before it starts to move.
    1/8th" per foot is better if you can fit it in the length.
    david
    Dec 2006
    Quote Originally Posted by Verdeboy View Post
    Sorry I missed this, hope you catch it anyways - the fittings are to allow for expansinon & contraction. If you rivet them, they'll buckle.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
