Results 1 to 8 of 8
Thread: prier faucet sticking
    DIY Junior Member judge's Avatar
    Apr 2011
    ohio
    Default prier faucet sticking
    Now that the weather has finally turned, I attempted to get water from my outdoor prier faucet (green cap and knob) and water didn't come out. What is the root cause? How should I fix this? I have 2, same situation on both of them. Installed 3 years ago and no issues to date
    http://www.prier.com/product/P_164_Wall_Hydrant
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    May be the vacum breaker
    Are you sure they haven't been turned off with a remote valve?
    Sometimes a faucet in the front of the garage will have a shutoff on the warm wall.
    FWIW, some models of frost-proof hose bibs will drain regardless of whether there's a hose attached or not. If I were going to install one, I'd look for one with that feature. These things have the actual guts that shut it off way at the end, inside the house. But, if there's a hose attached, most can't drain, and this can split the pipe. Won't leak until you turn it back on.
    Apr 2011
    ohio
    Thanks for the reply. Yes, I have confirmed that the remote valves in my basement are "on". There doesn't appear to be any split pipe situation. There seemed to be a small bit of leakage, maybe 20 drops, that dripped out when I attempted to first open the faucet. I'm not an experienced plumber, so I don't know whether there is a vacuum breaker, and how to activate it.
    Should I attempt to remove the knob and nut to see whether something is "stuck"?
    Director of sales and marketing NPMSTR's Avatar
    Dec 2004
    Kansas
    Turn the shutoff valve OFF, using a crescent wrench, loosen the nut behind the handle and after is it loose, unthread the stem out of the valve. Inspect the stem and make sure it is complete. Once the valve is out of the hydrant, turn the water on to flush out the hydrant, after flushing the hydrant, reinstall and stem and valve stem cap, and you should be repaired.
    DIY Junior Member westflo's Avatar
    May 2011
    Missouri
    Quote Originally Posted by NPMSTR View Post
    Thanks for this great video that explains more this valve. It seems nice. I think this is what I'll use next when my currect valve breaks.
    Dec 2007
    Basically you just overtightened it when you shut it off last fall and it is stuck.
    Good to see Prier is onboard with a video I was getting tired of explaining that every spring on the forums...
  1. Prier frost-free faucet leaking from handle
    By maddfrog in forum Plumbing Forum Discussion & Blog
    Last Post: 07-01-2010, 05:32 AM
  2. Prier silcock turns on by itself
    By Botoo in forum Plumbing Forum Discussion & Blog
    Last Post: 12-15-2009, 03:19 PM
  3. Prier Outdoor Faucet Plastic Cap
    By teqnic in forum Plumbing Forum Discussion & Blog
    Last Post: 06-26-2009, 04:47 AM
  4. handle sticking
    By wjd in forum Toilet Forum discussions
    Last Post: 10-06-2005, 08:46 AM
  5. Fittings sticking out too far
    By KG in forum Shower & bathtub Forum & Blog
    Last Post: 08-31-2005, 02:54 PM
