Results 1 to 6 of 6
Thread: spliced 10 -3 wire question
    Question spliced 10 -3 wire question
    hello, just removed a drop ceiling and found wires above. one wire was a 12-2 and the other was either 10-3 or 12-3. bought extra wire for each spliced each one and connected each to seperate exposed junction boxes on wall. the 10-3 has power when i touch hot to ground and hot to nuetral. the 12-2 has no power now so both original outlets dont work. seems simple but i am at a loss. am i doing anything wrong?? thanx for your time!
    Dec 2006
    "Spliced" how, exactly?
    We need more info, like a diagram or something - at least an explanation with more detail...
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    mark, simply cut the 12-2 and the 10-3 then added extra length of each , connected the wires inside junction boxes. basically lengthened each run and attached them to wall so wires wouldn't be hanging from ceiling. hope this helps! thanx bill
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    I was totally confused by the first post. I get it a little clearer now.
    If that is all you did you simply mixed something up.
    EVERYTHING you did should have been color-for-color, wire-for-wire.
    Re-check every splice.
    Jun 2007
    North Carolina
    Quote Originally Posted by capnwill
    hello, just removed a drop ceiling and found wires above. thanx for your time!
    mark, hope this helps! thanx bill
    Quote Originally Posted by Speedy Petey
    I an totally confused by the first and third post. Is this two different people using the same user name such as Mark and Bill or is this one person using two different sir names?
    NM cable above a lay-in ceiling???????? Hope this is in a residence.
    Dec 2006
    Quote Originally Posted by jwelectric
    I think the 3rd post:
    is his answer to:
    and he thinks my name is Mark because my signature line starts with a quote from Master Plumber Mark.
    It would have be less confusing if he'd written "Mark, I simply cut..."
    __________________
