Push Button urnial
erthwrks89
Greetings--- I have a urnial with the old type manual push button flush, The only writing I can find on the breaker, Sloan Valve Co . I went to Sloans website but can't find the type of flush valve I have. The breaker is a v500. The problem is the water will not shut off . I would like to get a repair kit . Any Idea who would make this type of valve? Thanks Bill
Patrick88
Webster Ma.
Checking the sloan web page comes up with a few buttom style valves. checking the pages for the v500 comes up empty. Ya I know you knew that, so taking a picture of the valve will help alot.
Peanut9199
Ontario, Canada
V-500-AA is the Vacuum breaker assembly for the valve.
5323005 is 3/4" x 9" which is for the urinal
5323006 is 1-1/4" x 9 which is old style urinal
5323007 is 1-1/2" x 9 which is for a toilet.
They have tons of Repair and rebuid kits but you would need to find out which one you have, can you take a picture and e-mail it to
ussales.411@sloanvalve.com they should be able to identify it for you.
GrumpyPlumber
Licensed Grump
Licensed Grump
You either need to clean the diaghram, or replace it.
The chrome top on the valve comes off with a "spud" wrench, or any flat non serated wrench thats big enough (so not to ruin the polished finish).
Take out the black disk, hold it up to a light, you should see a pinhole on the disk.
If not, clean it & re-assemble.
Any plumbing supply should have it if you need to replace it.
erthwrks89
Heres a picture ---I found Chicago Faucet Co on the valve . The old eyes aren't what they use to be ----------Thanks Bill
Patrick88
Webster Ma.
That is one interesting valve. It does look rather old. Should get a new motion sensor valve. I don't care for touching those things.
erthwrks89
Patrick 88 ---------- Is there a sensor valve that would" Bolt Up"----Would that just take the place of the valve or the breaker also? Bill
Peanut9199
Ontario, Canada
